Hola quisiera saber que pluying sirve para mi Foro ya que tengo el 1.6.3 y el pluying de publicidad dice que no es compatiblie que debo hacer...
Gracias...
Gracias...
( ! ) Deprecated: preg_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /var/www/mybb-es.com/inc/plugins/google_seo/redirect.php on line 298 | ||||
Call Stack | ||||
# | Time | Memory | Function | Location |
1 | 0.0001 | 378648 | {main}( ) | .../showthread.php:0 |
2 | 0.0002 | 403576 | require_once( '/var/www/mybb-es.com/global.php ) | .../showthread.php:28 |
3 | 0.0076 | 1727472 | pluginSystem->run_hooks( $hook = 'global_start', $arguments = ??? ) | .../global.php:100 |
4 | 0.0076 | 1727504 | google_seo_redirect_hook( '' ) | .../class_plugins.php:142 |
5 | 0.0079 | 1728272 | preg_replace( $pattern = '/\\?([^&?=]+)([=&])/u', $replacement = '&$1$2', $subject = NULL ) | .../redirect.php:298 |
( ! ) Deprecated: parse_str(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/mybb-es.com/inc/plugins/google_seo/redirect.php on line 315 | ||||
Call Stack | ||||
5 | 0.0081 | 1729152 | parse_str( $string = NULL, $result = NULL ) | .../redirect.php:315 |
<table class="tborder"><tr><td>CODIGO</td></tr></table>
